I can get the HSD to go into EV mode in the morning by using the following practice: Turn on the car as normal (note: the cabin heater and seat heaters must be OFF or the computer will think that you want heat - which is provided by the warmth from the radiator fluid -- and will keep the ICE running to meet the demand from the HVAC system to provide heat) and let it run through its initial system check. I believe that this is S0 (when it's already warmed up or warm days) and through S1 when its cold (below40c) and/or the first start on a cold morning. I let the ICE run until it stops. This lasts anywhere from ~60 seconds to a high of ~150 seconds. I then open the garage door and back out (I am NOT in EV mode) - and while granny footing the accelerator pedal, I can drive the entrance of my subdivision on elictirc power only (Golf Cart mode). I can reach speeds up to 35 mph, but that's slightly over the 'limit' for my neighborhood so I try to keep it under 35 mph.
During the initial warm up stages (S0~S1), while sitting still in my garage, I will lose .2 MPG, but I gain .3 ~ .4 MPG on my drive to the entrance so it's a net gain of .1 ~ .2 <-- OK, not much, but I "feel" better and I'm really, really quiet as I exit my neighborhood. Once I reach the main road, I must engage the ICE as it is required to meet the speed that the other traffic is doing so the remaining stages (S1b --> S4) are met in the next 1.0 ~ 1.5 miles. I also have one traffic light and stop signs that I encounter -- and by the 4th one, I have achieved S4 and can (if the accelerator pedal is pressed "easy") drive in electric mode once the "idling check ceremony" has finished.
If I have the "Got to's and can't help it's" and have to have heat, I will turn on the seat heater and warm up that way until after the sytem achieves S4 - and even then I try to limit the use of the HVAC system unless I am above 42 mph (the ICE spins above 42 mph anyway, so it might as well be providing power). Once S4 has been achieved, you can also turn on your HVAC, reach your desired cabin temp and then switch it off. If you have the system set to provide fersh air (not recirculating) then the "flow" of air into the system will provide enough heat to maintain the cabin temps unless its really really cold outside.
note: these examples are with both my HyHi and the PriusG3. My CT is due within the next 30 days so I'm eager to see if there are improvements to the way that the HSD functions on my daily commute.
note2: when returning home, I use a similar practice although I have a lesser distance to travel until I reach the major road where I must keep up with traffic (I'm not a Hybrid driver that impedes other drivers in order to reach max mpg. I get my satisfaction at the pump each time I fill up).
note3: I've noticed ~10% drop in MPG since we switched over the the winter formulation gas. If I am unlucky enough to have to fill up with 10% ethenol gas (not all stations carry it so I try to avoid those that do), I also get ~10% penalty in my MPG. Winter formulation gas + 10% ethenol = "ouch"
