Hello world,
My 2013 CT200H does not start. I'm getting DTC code P0A0F-238. Hybrid Battery seems okay and car does drive on EV mode only but shuts of after 100 yards for driving.
Please help me diagnose the issue.
2016 CT200h F Sport, Silver Lining Metallic
Whats the oil level like in your engine?
Any problems previously of coolant in the oil? Knocking? Overheating?
Tech Tip for this code suggests the following: "If this DTC is output, the engine or transmission gear may be seized. Be sure to check the level of the engine oil, automatic transmission fluid (ATF) and coolant before inspection. "
Another simple check...have someone start the car in Park, and have the engine running...with the hood up check to see if the crank pulley is moving. If not, it may be serious.
