Has anyone attempted to remove the clear door edge trim? I bought my car with 10,000 miles on it and it has the optional door edge trim and I hate it. Anyone removed it yet? I'm thinking I'll be okay with a hair dryer but would like to make sure first.
Is the 3M clear plastic material. If so should come off fairly easily - hair dryer will help then light compound and wax.
It is the clear plastic edge protector available from the dealer so I assume it is 3M but I am not certain. All I know is that it has to go.
Just pull it off from one end or the other and remove the remaining adhesive with some sort of solvent, preferably alcohol, if that doesn't work, start going up with something designed to remove adhesives like Goop or Oops, they are fairly mild solvents.
