This is for an Android app called Torque. It uses wireless connection (WiFi or Bluetooth) to connect an OBDII device to Android phone running Torque app ($5). I am using Kiwi Bluetooth OBDII device ($99) from PLX. Some people reported cheap clone (~$30) from ebay works as well. However they are either a hit or a miss. I have a clone and it doesn't work with CAN bus where hybrid information are.
Torque already has some basic PIDs but the goal is to add addition PIDs and extract hybrid specific information. These are based on the Gen3 Prius so let me know if anything does not work for CT200h.
The following PIDs are available:
Installation Instruction
Using a PC or Mac, simply put the CSV file in ".torque/extendedpids" folder on your micro SD card. Keep in mind that ".torque" folder is hidden so set your explorer to show the hidden folders.
Once the micro SD card is inserted and mounted in the phone/tablet follow this. In Torque main screen, press Menu -> Settings -> Manage extra PIDs/Sensors -> Menu -> Add predefined set
This is my setup in 2006 Prius.
Reference for future updates.
- Regen Cooperation
- Fuel Input
- Fuel Input
- Room Temp
- Calculated Load
- Vehicle Load
- Atmosphere pressure
- Engine coolant temperature
- Injection volume (Cylinder 1) for 10 times
- Injection duration for cylinder 1
- State of Charge
- Ambient Temperature
- MG1 temperature
- MG1 revolution
- MG2 temperature
- MG2 revolution
- MG1 torque
- MG2 torque
- Inverter MG1 Temp
- Inverter MG2 Temp
- High voltage before it is boosted
- High voltage after it is boosted
- Boost converter temperature (upper)
- Boost converter temperature (lower)
- Inverter Coolant Temp
- MG1 Carrier Frequency
- MG2 Carrier Frequency
- A/C consumption power
- Battery Block Voltage -V01
- Battery Block Voltage -V02
- Battery Block Voltage -V03
- Battery Block Voltage -V04
- Battery Block Voltage -V05
- Battery Block Voltage -V06
- Battery Block Voltage -V07
- Battery Block Voltage -V08
- Battery Block Voltage -V09
- Battery Block Voltage -V10
- Battery Block Voltage -V11
- Battery Block Voltage -V12
- Battery Block Voltage -V13
- Battery Block Voltage -V14
- Traction Battery Temp
- Temp of Batt TB1
- Temp of Batt TB2
- Temp of Batt TB3
- Battery pack current
- Internal Resistance R01
- Internal Resistance R02
- Internal Resistance R03
- Internal Resistance R04
- Internal Resistance R05
- Internal Resistance R06
- Internal Resistance R07
- Internal Resistance R08
- Internal Resistance R09
- Internal Resistance R10
- Internal Resistance R11
- Internal Resistance R12
- Internal Resistance R13
- Internal Resistance R14
- HV battery discharge control
- HV battery charge control
