1 - 20 of 33 Posts
This is awesome. I was planning on putting a hitch on my car as well. How sturdy is this hitch and how well does it hold your bike?
The hitch is massively sturdy for carrying bikes. It is attached to the CT frame with 4 M12-1.25x30mm hex bolts. You could easily carry the weight of four modern bicycles. Heck you could theoretically tow one ton with it. Here are the specs:
Rating: Class I
Maximum gross trailer weight: 2,000 lbs
Maximum tongue weight: 200 lbs
Curt Manufacturing does provide the following note:
Note: All non-trailer loads - bike racks, cargo carriers and so forth - should be supported with stabilizing straps. Failure to properly support these loads will void your hitch warranty from CURT.
I used a similar curt hitch on my former ride. It had the same specs and I pulled a trailler loaded with two GasGas trials motorcycles, through mountains, over gravel roads and rough terrain. I have complete faith in these hitches. After selling the trials bikes and trailer, I bought the Yakima hitch-mount bike carrier. I had great results with it.
Who Said Box Can't Tow? by peckhammer, on Flickr
Discussion Starter #6
How often do you scrape the hitch?
On the CT? It's only been on the car for a few days, but it never scraped once. On my former car, however, we called it the spark generator when there were a couple of adults in the back seat.
You knew someone was going to ask, so I'll just blurt it out:
How did the addition of the bike rack affect mileage? Either loaded or unloaded? =]
Discussion Starter #11
I noticed no difference, but my sample rate is small... IOW, I have not done a bunch of highway miles with the bikes on the car; only city driving. I think it's possible to lower your highway mileage due to wind resistance with bikes on the carrier, but I would not expect to see a huge difference.
Thanks so much for doing all the hard work researching this. I am way too short to consider a roof mount system. My pink cruiser bicycle is going to look so cute mounted on the back of my ct.
I installed this hitch without a jack and did not have any problems. It seems very sturdy.
Has anyone used the support strap? I bought it, but it seems a though it puts a lot of pressure on the rear spoiler.
When I had my HS250h I did a cross-country drive with 2 bikes on a Swagman hitch-mounted carrier. Highway fuel consumption increased by about 15%. I don't know if the effect will be the same with the CT as it has different aerodynamics than the HS.
Got a one of these put on and a swagman bike rack. Mpg dropped a little,but I so have different wheels and tires so that doesn't help.
Went with the CURT hitch & Thule T2. Only 25 miles on the fully loaded setup, but so far it seems quite nice. No additional road noise, easy to installed/remove the bike.
1 - 20 of 33 Posts
