Hi, I recently purchased a pre owned 2ZR-FXE engine as my original one was damage (HG blown, rods bent). The 'new' engine was installed but the shudder/rattle hasn't gone away. Is there something additional that one has to do. Is it not just plug and play, doing the swap?
Discussion Starter · #2 ·
Recheck ground straps, block and head straps.. Check coils out after that, start with connections and wires.. for sure with a swap you have new plugs in at .041 i assume..
Can you confirm the cylinder number misfiring? If so swap coils and test, did the misfire move? If so ya found a dead coil..
Keep us posted, some smart people that know a thing or two are out here 👍
