I accidentally sold my OE Prius wheels with my CT200h wheel lug nuts. :(
I cannot get the lugs back until next week and I had planned to install the CT wheels with new tires this week. Will the Prius lug nuts work? They physically fit inside the wheel and they stop at the back plate of the hub so everything seems good.
Here is what they look like.
I bought a set of 2012 prius wheels to run snows on and I believe that the bolts are identical. However, you should check with your Toyota dealer to be safe.
Thanks, Boston. From everything I have been able to find they are the same. I'll post back to confirm after the install.
Boston GTR: What size Prius rims did you get? Are they steelies or rims? How much did they cost? Any pics of the setup?
Discussion Starter #6
Those OE 2012 Prius wheels weigh approx. 16lbs. Have a +45mm offset and are 15x6. They are identical to the 2010-2011 wheels except they are black and come with different wheel caps although those are interchangeable.
Discussion Starter #7
The nuts are identical. Thanks, Boston. :)
