Ok, i was dissapointed that my CT hasn't cruise control. So, if you feel the same
, then you will need the folowing stuff:
1. 8463234011 cruise control switch (for cars without PCS)
2. 8463348020 wire
3. 4518676010C0 cover steering wheel
4. screw M5 10mm x2 (i'm not used original)
5. free time ~ 30 min and can of favorite beer
The steps:
First of all and important, take off the minus wire from the 12V battery and wait ~2 minutes.
Then take off the covers from the both sides of the steering wheel (use thin screwdriver)
Now we need: from the left side push down lower steel wire and push up upper (look at red circles on image), from the right side only upper.
Carefully pull the driver airbag...
.. and we will see this
yellow circle - wire connection hole
red circles - switch mount holes
Ok, now insert the switch inside and place over holes
Connect wire, screw bolts.. we almost finished
Now, get the driver airbag back (just place it over and push), left cover and new right cover.
Thats it!
Connect the minus to 12V battery and turn the engine ON.
The new green indicator is telling us that now we got CC!!!
2. 8463348020 wire
The steps:
Thats it!
