41 - 60 of 60 Posts
So I've had this exact problem 3 times. The first 2 were when it was in the single digits. The 3rd time was when I hadn't driven it for a week and it was below 40 degrees. I've read the service bulletin. I am very close to the end of my warranty and it did it again the other morning. I scheduled an appointment and dropped it off with all the information needed to have the fix. I talked to the mechanic and left notes about the service bulletin. When they called back they told me they won't be swapping out the intake manifold. They told me that they have to physically witness the problem to take any action. I asked if I could video tape it. They said that isn't good enough. Thanks... So basically they ran out the timer on my warranty and if I want it fixed I have to pay full price. I find that VERY anti consumer. If you know for a fact that certain model years have this problem make it a recall. I get they want evidence but keeping it in a garage overnight won't provide the cold start let me tell you that. I had to drive 600 miles to get my oil changed and an alignment. Which cost me about $180. I guess I'll just do all my own maintenance from now on. 2012 ct 200h f sport. 52k miles.
I ve started the car with the remote starter this morning. When i heard the knocking i took my phone and started to record. This is a start from -20c.
Just like mine sounded last year but I didn’t let it run that long.
After numerous overdoses of fuel injector cleaner and spirited driving in Sport mode it hasn’t done it since.
@o_tomodo: Good job, bud. Glad someone caught it on video when it was that loud and bad-sounding. I took a quick video once but from inside. Yours really brings out how bad it can sound in person. Gonna show it to my mechanic.
You have the newer car 2014+ the TSB is for the 2011-13.
What year and how many miles you you have on yours?
It a 2014 bought in August 2013, i m the second owner. The car has 66000 km(41000mi)
It s the second time this happens in a month (very cold month)
I have a 2011 model, with nearly 300,000km, I have had the same problem on and off since I purchased the car. I mentioned it to Lexus but they were unable to replicate the issue. All the videos are exactly the same, some of mine last longer than others. However, I do notice that if the car is not used in a few days and it is cold, it does the rattling and shaking. So far the car is fine, I will now try and log the events for future reference.
As a 2011 Lexus owner, I received a letter from Lexus Canada saying that I am enrolled into warranty enhancement program, where there the car could idle rough or have loud noise at cold start along with an engine light and that I should bring my car in if it experienced the symptoms.
Until recently I experienced the exact symptoms where the car will have a loud noise and threw and engine code, naturally I brought it in along with an airbag recall.
Now the dealership is charging me $160+tax because they said the code that was scanned doesn't match up the code on the letter.
How as a customer we can protect or even benefit ourselves from this so called warranty enhancement program, even if we experience what was said on the program letter we are taking our on chance, either hope that the code matches up or risk paying $160+tax for a diagnostic fee for a simple code scan.
So as the customer, we are taking our on chance because we won't be able to scan the code other than matching the apparent symptoms on the letter itself (loud noise at start up + engine light)
So is this $160+tax a way to deter customers that are entitled to get coverage under this so called Warranty Enhancement program, which oriented from Lexus using an inferior part from the beginning?
Or is it just another way of money grabbing?
Calling Lexus Canada Customer service is of no help and they basically say you are on your own. Is this how your treat your customers, Lexus Canada?
If it happens again and it throws a code, i have the obd2 bluetooth scanner and the code will be checked before they see it.
I have a 15 ct and my car has done this a couple of times. It actually happened couple days ago and I only have 49k on her. But no lights appeared on dash. ?‍♂ Has the dealer solved this issue?
I almost reproduced the knocking this winter.
We had around 10cm of snow and i had to remove the ct out of the driveway. The engine was on for 30sec. and i stopped it. An hour later i went back and got the car back on the driveway. Another 30sec. of engine running.
The next day, i went to the store and didn't use the remote starter. I started the car normally and heard a bit of knocking for about 5sec. .
Another snowfall and i had to move it in front of the garage. Next day i had the same result.
My thoughts is the regular gas containing ethanol. This winter every 3 fills, i use 91 octane gas, instead of 87 octane. We use half a tank per week. I didn't heard a single knock again and we had a lot of snowfalls.
Cold Start Recall
The symptoms (shudder on cold start, white smoke from tailpipe, possible misfires) point to the head gasket; however, it could be the intake manifold and/or EGR valve. Lexus has a Technical Service Bulletin, L-SB-0004-13, to address the intake manifold allowing moisture in the engine. They replaced the part number with a new one, 1712037054. I would encourage everyone having these problems to file a complaint with the Better Business Bureau and the NHTSA. I experienced these issues intermittently for about a month and I had Lexus replace the manifold last week. This week, I blew a rod in my engine with 120,000 miles. I never had any issues with my engine, and I changed my oil regularly with Mobile 0W-20. My concern is excessive moisture in the engine may cause premature engine failure. If your engine fails while you're driving, it could be a safety issue.
I've had this with all Toyota hybrids (Gen 2 and 3 Prius, 2014 Prius V, and 2011 CT) I've owned. Similar designs so I'm not surprised. Usually not a big deal but once recently I had my car parked at the airport for a week in very cold weather and when I started it the rattling and vibration was so bad!! I had to manually raise the idle rpms to get it to "work itself out". Once I started driving it went away and was fine. Sounded like the engine was coming apart, crazy. Normally doesn't happen though, that was a pretty isolated case to be that bad. I've got 92K miles.
Did the dealership help remedy this issue? I have brought my car back several times but the rattling continues and LEXUS will not assist as they are saying it due to another issue. What are some of your reccomendations?
I have a 2012 Ct200h F-sport with 145,000 miles. Started about 8 weeks ago Code said misfire in cylinder 1.
As they were all original I opted to change all plugs and ignition coils. I put Techtron in and ran it about 300 miles, Thought it was fixed, light reset , Tpms Monitor lights reset and all was good in the world. Then BAM, Shutter started again, Check engine light on and Tpms light on, AND Coolant light came on. Off to AutoZone they replaced the Bosch Plugs and all Four ignition coils because OBD now stated misfire in 1 &3. Put them in and I noticed low coolant and white exhaust( head gasket?) Car ran good for about 30 miles then shudder is back, coolant was down a pint, oil level is unchanged. no drips or leaks on floor White smoke is minimal BUT shudder is almost EVERY time the car starts or kicks out of EV mode. Anything involving more than an oil, plug or brake change is beyond my comfort level, I don't want to go to Lexus as the nearest dealer is over 100 miles. Toyota wasn't interested in even looking at it, My 2010 Prius has 156000 mikes with the original plugs and coils and is just starting to be a little rough upon cold start. I fear it is going the way of the Lexus, ANY thoughts would be GREATLY appreciated. Would the Timing Belt have anything to do with this??
2015 eminent white pearl
White smoke...blown head gasket. Coolant leak into cylinders fowling your plugs and causing misfire. Prolly
i know this is an old post, but relevant..
Everyone needs to know what this is, and what to do.. 👍
Simple simple simple..
Starts Banging SHUT IT DOWN..
Don’t let these Atkinson engines bang..
They don’t like it, and it will cause damage rather quickly, like Less than 30minutes quickly..
Change the plugs, Ensure gaps are .041
Still a bang, coil going out, Replace them
Have a nice day..
Don’t fret this EGR money dump scam, system is designed to warn driver of EGR Restrictions, clean it then..
Mind you, this is IF you catch it fast enough.. Like don’t drive home or to the dealership Banging away..
Let it bang, well your in for a few surprises-
1- intake manifold gasket goes out
2- head gasket goes out
3- wrist pin circlip pops
4- throw a rod out the side of the block
so what is this Bang “?”
It is an out of order firing of gases in the cylinder head behind the valves when a spark plug is not firing.. Want to test this yourself, pop the hood unplug a spark plug coil, or pull the coil over plug off the spark plug, go start it for a second.. Bang Bang.. This procedure is called Duplicating The Complaint, at dealerships that say they Can’t Duplicate the customers complaint..
Atkinson engines have a valve timing for fuel efficiency, some gases blow back for reburn.. Spark plug not firing, the next cylinder fires the unburnt gases, explosions in the cylinder head.. that’s enough to take out the intake gasket if left banging till it clears up.. While this is happening we have an out of thermal balance of heat at cylinder Deck, allowing uneven thermal expansion of the cylinder head, takes the head gasket out.. Like sandpaper.. Let us not forget, as SOON as it starts banging we have undue stresses on the wrist-pin, that if left Banging, takes the circlip out that hold the wrist-pin in place.. well now that holds the piston and connecting rod together.. Boom throw a rod out the side of the block, it’s done..
this all cumulates to Having a Bad day..
and yes the Manual is Wrong..
Change plugs every 60,000 miles, not 120,000 miles as per Properly Dealership Maintained
that’s it.. Enjoy your CT’s and Prius’s and Ford Fusions and anything else using the Atkinson engine
41 - 60 of 60 Posts
