Brake Caliper Paint
483 Views 11 Replies 3 Participants Last post by  GreenQueenSD
I’m thinking of doing my brake calipers in a lime green and since you all are so awesome I am asking your opinions. I have looked at 2 different paints and curious which y’all would recommend and also would I need to put primer on them or just clean them? These are my paint choices
or
G2 High Temperature Brake Caliper Paint Kit - High Gloss, Wear and Heat Resistant, Epoxy Paint System - Dries Hard, No Flaking or Fading Lime Green G2171 https://a.co/d/dRNusmz
1 - 12 of 12 Posts
@NewShockerGuy painted his calipers blue. So if you look at his posts, you will find helpful tips there. Or maybe he will chime in here.
However, for painting brake calipers, it is the same as any car. So there are probably good videos online or write ups in other places already in general that are better than what I could say, since I never tried. But I think the Amazon link looks like a better green color.
  • Like
Reactions: 1
I seen the old thread but with the old ones I always read them, but it says start a new one because people likely won’t reply to the old ones. I don’t like making duplicate ones. If I should rekindle the old ones I can do that or make a new one just let me know what’s best.
as for the colors they are almost identical and I’m trying to match almost lime green. I just assumed the spray version might be easier than painting them with a brush but didn’t want to sacrifice quality just to spray them. The old thread is how I found out about the Dupli-Color Engine paint.
6
It's ALL in the prep with whatever you choose.
G2 is time consuming. The amount of cleaning you have to do to make sure there is no brake dust and or rust...etc. Everytime I do it I ask myself half way in why I just didn't buy new calipers and send them to a powder coater... it would be cheaper and it would never come off. Keep in mind whatever you do will eventually chip/flake off. As much as I like g2 caliper paint and it is what I used on the CT, all cases I've done it will last several years before it starts to eventually come off.
G2 should be stronger than anything from a can because you are mixing hardener with the paint. That will make it much stronger than what's coming out of a spray can short of you following up witha 2k clear coat. This isn't a hard project but just time consuming with the amount of cleaning/then multiple coats. I did 4 coats on the CT's calipers. I probably could have squeezed in another 5th coat but by the time you have between coats and then eventually having the paint getting harder it wasn't worth the risk of seeing streaks or globs.
It's important to know if you do go with g2 caliper paint NOT to use their brake cleaner that is provided. It's non-chlorinated. Why is that important? It leaves a residue behind which is not what you want when applying paint. You want something like the Brake Klean Chlorinated stuff. You can buy a gallon of it on Amazon. Metal wire brushes are your friend in cleaning them up. They can never be too clean.
You also don't want to use the crappy brush that's supplied in the kit. The bristles will fall out and leave a mess. Go to lowes and by the cheap $1 brushes and buy like 5 of them. Cut the bristles down shorter as it's easier to paint compared to if the bristles are long. Then after each coat on all 4 calipers, throw the brush out and use a new one. It will make your life way easier.
I do think it looks nice. Luckily my car came from FL so there was no salt /rust on them like it would have been here in VA or PA after a year or so. if there was I would have just bought new calipers. I would say the total time that I spent was at least 6+ hours on the calipers.
It's a subtle look. I choose blue because of the hybrid theme and will continue the blue theme to the headlights I'm doing starting in june.
Table Blue Tableware Drinkware Wood
Automotive tire Motor vehicle Vehicle brake Wheel Automotive care
Automotive tire Motor vehicle Wheel Automotive design Locking hubs
Wheel Automotive tire Locking hubs Vehicle Motor vehicle
Automotive tire Wheel Tread Motor vehicle Tire
Tire Wheel Land vehicle Car Vehicle
I didn't want anything flashy since they are tiny calipers. G2 works best on this type of caliper in my opinion rather than a huge smooth brembo. The texture on the caliper helps greatly.
-Nigel
  • Like
  • Love
Reactions: 3
Sorry to ask but in this case would it be a better option to go with caliper covers?
That does look good, and I live in SoCal so no worries with rust either but it’s not something I want to have done again in a couple years.
Caliper covers are tacky AF in my opinion. They draw attention to something that shouldn't have attention brought to them plus they look fake. You're better off not doing anything than getting caliper covers in my opinion...lol
It'll probably last longer for you since you don't see snow/salt. Here in VA they use salt and salt eventually destroys anything... If I lived down south they would probably last longer. How I combat that now is driving only certain cars we only in the winter time and that has greatly helped on things. We don't get that much snow each year but when we do they like to go nuts with salt. It also depends on if you take your car into a dealer and when they remove or put the wheels back on if they hit the caliper. That's one of the reason why I don't even take my RCF into the dealer to do any scheduled maintance. I don't want them chipping the calipers by man handling the wheels. I do all maintenance myself.
-Nigel
  • Like
Reactions: 1
They are really clean already maybe a little brake dust but that’s about it, my friend inspected them when we Plasti-dipped my wheels. I think the brush would be easier because he won’t have to come take them off. I just wasn’t sure about the covers a lot of them do not have good reviews so I thought I would ask some of you about it. I would paint my valve stem covers also so they are matching green.
Do yourself a favor and remove the calipers. It's super easy and you won't spend just as long masking stuff off to paint around it or not paint something you shouldn't...etc. In the one picture you can see I removed the caliper and bracket. Then once I painted the bracket a couple time I ended putting that back on the car and loosly bolted the caliper on the bracket. Made it much easier to paint without pads in. Otherwise, you are going to not have a good look because paint will be in places you don't want it. EVEN with the caliper off like that I ended up getting paint in spots so I can't imagine doing it will the caliper fully loaded with pads..etc.. Very easy to do plus it ensure you get all the brake dust off the caliper by removing the pads. Remember you want to paint as much of the caliper as possible. If you don't hit areas with paint, you run the risk of that area then getting lifted off and the paint failing.
I painted the inside of the caliper as well minus the rubber boot. If you looked at the caliper you would think it was powder coated with how it's fully covered.
-Nigel
I wouldn’t have thought to paint the whole thin I was just going to do the visabe part. Thank you for that info I will look for some YouTube tutorials on how to do it.
So I ordered the G2 Lime Green Caliper Paint. I’m going to take a little bit and paint my valve stem covers with it as well so they match. I am struggling to find a lime green license plate frame that will match this paint. Starting to think I should have went with pink there are more options there.
You could probably paint the license plate frame with the G2 lime green paint.
  • Like
Reactions: 1
True I was just hoping for maybe a cool black/lime green combo to match my black tags. Like the wheels will be black with lime highlights and the license plates black with lime highlights. I ordered a set on Amazon but they didn’t look the same when they arrived. If it looked like the picture they would be perfect.
1 - 12 of 12 Posts
