Here is where I've ended up. I know that the oil level was low when getting close to time for an oil change for the last 2 oil changes, and I mean considerably low (below the lower line). The coolant I honestly couldn't tell you because I hadn't monitored it because I hadn't experienced any overheating issues. The level was supposed to be checked and/or topped off at oil changes, but there was no mention of it by the service techs.
I haven't checked the oil level since doing the work that I've done so far, which is such: pulled intake manifold, throttle body, and egr system and thoroughly cleaned them. There was some oil pooling in the bottom of the intake manifold when I pulled it, and I went ahead and did the PCV valve after having pulled everything else. I've since changed the plugs and ignition coils.
Initial cause of concern was the hard shudder and CEL for cylinder 1. I changed oil and plugs after this and had it reset before having another hard start and moving on to egr work. After doing egr/intake manifold/throttle body work it ran smoothly for first few starts and then had hard shudder once more and CEL came back. CEL was now for a misfire in both cylinder 1 and cylinder 2.
Bought the ignition coils and swapped them and am still experiencing hard shudder with CEL being thrown. Haven't had the codes scanned yet.
I also haven't checked the oil level, which I would assume is still near the top line on the dip stick. The coolant level has remained, but it hasn't been driven more than 10 miles as that sound from the hard shudder sends chills and makes me worry for further damage.
I am curious to know if that drop in oil level has been that significant for you. That seems bizarrely simple.
And to add to this...I have had the oil changes done with the recommended 0w20 full synthetic and have had them done every 7500 miles.
