2011 Ct200h ... no problems operationally... noticed a black pile of goop that looks like it ran out from under the dash, and hardened. It mostly hit the floormat, but also ran underneath the passenger side floormat. It doesn't look like anything melted, didn't smell, can't tell where it came from... Any ideas?
I just found the same thing in my 2011 CT200h. I pulled off the plastic panel under the glove box and found a wad of the tar/plastic laminate that seems to have melted and moved from some other place in the bowels of the dash, but I can't tell from where. I was trying to find out why I am not getting any heat on the passenger side. No heat, no defrost, just cold air--the driver's side heat and a/c work perfectly fine. I can't find much information on how to fix this, or what exactly is causing the problem. Can anyone shed any light on this??
I found the same thing. It was like a handful of melted tar that was dripping onto the passenger floormat. WTF???
I found a same handful melted substance on the passenger floormat. Doe anyone knows wat it is?
