I did a test today with the extreme heat:
I had the battery fully charged after a long run today and decided to see how long the battery could support the car running the AC and the radio while parked in 33o(C) heat.
I was able to get between 11 and 12 minutes before the engine kicked in to start charging the battery again.
That's pretty good IMO.
Boldlygo, where was the battery indicator when the engine came on?
It 2 bars left and they had changed to dark purple colour.
Nice, ok your next assignment is to take exactly one gallon of gasoline with you, drive until you run out of gas, add the one gallon to the tank, go to gas station and fill up and note the fill, that's to answer the other thread of exactly how much gas does the tank hold so we can close out that discussion. Good luck.
