I just took possession of my CT200. I have a back up camera but I feel I need back up sensors too. I've installed these on many new cars. The problem I'm having is finding the best place to tap into the back up lamp wiring. Since the lamps are in the door, and I can see where the wiring goes from the top of the hatch into the body but where do I access the wiring after that?
Have any of you done this and if so HELP!
Thanks,
i feel it depends on where you are mounting the backup camera,if you are locating it where lexus fit the camera then take you feeds from inside the rear door,
if not then i feel you need to look at the routing of the cabling to see how accessible the wiring is then base your decision on your findings.
