I noticed (2) ambient blue lights by the homelink buttons. however, the one on the drivers side is never lit. Should it always be lit? I noticed the passenger side is always lit. Never knew they existed until I saw my hand light up when pushing the buttons at night. Thanks.
Discussion Starter · #7 ·
Thank you. I tested and you're exactly right. I saw the switch from the blue ambient light to the red ambient light. Never put it in sports mode before, so was also impressed with the change from the power band display to the tachometer.
There are 2 set of of ambient light. Blue when you drive under 'Normal or ECO' mode. The 'other' ambient light is Red color if you select 'Sports' mode. Can't have both lit at the same time.
