Hello,
My Premium Audio system is acting weird...
I am able to comfortably listen to SAT and FM at level 15, but I need to crank it up to 33 to get the same volume on CD or AM (especially AM).
Also, the AM sounds muffled at this level.
I've checked the EQ to make sure things are the same there.
Any help would be appreciated.
Thank You!
Hello,
Thank You!
The same thing happens in my car,
At any given setting, the volume level for FM is much higher than it is for any other audio source.
AM is the weakest.
Some of audio sources have their own independent volume setting (eg bluetooth audio), so the volume doesn’t necessarily change as you change audio sources.
AM and FM share the same volume setting. Changing the volume on AM effects the volume on FM. This is very annoying. :confused:
