My 2014 F Sport is due for new tires. They all look equally worn, but the inside tread is definitely more worn than the outside. Since they all look the same, I'm assuming that's how the car was set up. Or should I get it aligned? Just checking.
You tires shouldn't be wearing faster on one side versus another. I recommend a 4-wheel alignment after every new set of tires, otherwise you'll do the same thing to your new tires too. The fact that they all look the same might just indicate that you have a similar misalignment front and rear depending on the roads you drive on.
