Will try and get something up next week when its all done. Waiting on the newly released Air Lift 3H Air Management to come in.Can't wait to do the same. But worried about how loud the compressor will be in a hatch vs a trunk. I don't know if dynomatting it and building an inclosure will be enough. Any video or clips from the inside of the car?
Concept 3 Performance in Brea, here in SoCal.What shop did the install?
Looks badass! I'm thinking about doing mine also. Anything that you would change or do differently on the airbag setup?Concept 3 Performance in Brea, here in SoCal.
Any pics of the trunk setup? What brand struts/bags did you use?The setup is great, still trying to figure out my trunk. The setup is good, just need to class it up a little.
I am on Air Force Struts with Air Lift 3H Air ManagementAny pics of the trunk setup? What brand struts/bags did you use?
With the compressor in the trunk area is it noisy at all? Sorry for all the questions, I'm just trying to get a game plan on what I'm gonna do. How does it ride compared to a coilover setup?I am on Air Force Struts with Air Lift 3H Air Management
could you line the spare wheel well with some sound deadening foam and then make another floor panel to go on top of the control system and again use some more sound deadening foam to line the underside of the floorYes, it is noisy when it turns on, but there is no other place to put it. I placed in the spare tire well to try and cut some of the noise, plus the compressor is only on for a minute or less. I never had coilovers so can't compare the ride. It is stiffer compared to my Megan springs, but my ride height is lower. I now only rub when I turn hard and the tires hit the fender liner
Sure if you want to hide everything. I wanted mine to be seen so had the custom wood floor with plexiglas window made.could you line the spare wheel well with some sound deadening foam and then make another floor panel to go on top of the control system and again use some more sound deadening foam to line the underside of the floor
