I have a set of FOUR (4) 5mm hubcentric with a 54.1 bore (exact CT 200h size) in the 5x100 pattern.
You can run these spacers with your OEM lug nuts as if you go any bigger you would need extended studs.
These are a PERFECT fit to space out (push out) your wheels by 5mm.
These WILL make your OEM 10 spoke or F-Sport 10 spoke wheels perfectly flush with your fender for a nice wider stance.
(As I had them when I had my F-Sport wheels on)
or you can use these to make any Lexus CT 200h wheels 5mm wider.
These are custom made for the CT 200h as it is NOT universal 5 lug with a generic sized hub, THESE FIT PERFECTLY ON THE HUB AS IT IS THE SAME 54.1 BORE WITH THE 5X100 PCD PATTERN.
$60 SHIPPED via USPS Priority with delivery confirmation/tracking
