1 - 20 of 34 Posts
I decided to post this, to see if anyone else is having this issue.
I bought my CT200h in Pennsylvania. Back in PA it was difficult for me to get under 40MPG, even leaving it in sport mode and driving it like a sports car.
Moved to California, and drove the CT across the country. Since getting out here, my MPG has been miserable. If I want to stay above 40MPG, I have to put it in EV mode every time I accelerate from a stop, accelerating slower than all the Prius around me. It's embarrassing! People get pissed off because I'm accelerating slower than a Yugo! I never had to do that in PA. Out here, I also leave it in Ecco mode all the time.
At first I thought it was the summer gas they use out here. But now they have switched over to the winter gas. I'm still getting 36-38MPG. I did see 38MPG when I was driving cross country, but that was because I was driving on 75MPH roads. 80MPH is definitely not an economical speed.
Is anyone else having this issue? What happened to my CT? I'm sure the dealer is going to laugh at me if I try to complain about this. :(
I'm not even at 15k miles and have had all scheduled services and recalls done. Does anyone think the exhaust valve recall may have had something to do with this? Is the quality of gas really this bad out in California?
What is your tire pressure? cold weather can make that go down and if it does, so does your mileage. Just for testing, I let my tires get down to 31 psi and my mileage dropped to the 38 mpg range even if I worked hard at driving easy. I was normally keeping them around 3 psi high, getting 42 mpg (summer blend). I am now testing 41/40 psi on winter blend. The ride is a bit sharper but I don't even have to work at getting 43 mpg. btw, my commute is mostly freeway and hills. If traffic is bad, the mileage goes up. But on the weekend? well I would rather have a bit of fun in sport mode than drive in eco :)
My conclusion so far: mpg drops drastically with under-inflated tires. A few psi over recommended, 36/35, gives good mileage and yet a decent ride. 41/40 a bit more mileage but harsher ride. Still looking for that sweet spot, I think it may be 37/36. :) After I have my 10k checkup, I will drop the tires to 37/36 and let it run for a few tanks.
I live in California (Orange County). I get 43-48mpg using gas from my local Chevron/Shell station.
Take it to the dealer.
I purchased my CT in Pennsylvania also and have now owned it two years. I find that weather is a big culprit in declining gas mileage. You also must consider terrain. I live in an area that is slightly hilly and I take short trips. In the summer, I average around 41-42mpg. In the winter, I have averaged 35-37mpg. My belief is that the car uses gasoline to warm up in the winter to function the heater and defroster and the engine runs much longer leading to the decrease in mileage. Plus, I get the car defrosted and warmed up and then my trip is completed in a short distance which is harsh for gas mileage. I guess it sort of depends on your location in California and the terrain and climate.
Mpg seems to go down to 40 mpg or so during the winter without using the remote start. with the remote start it can go as low as 20 something for a short trip. I keep my tires inflated to near max and keep it around 42 to 45 mpg in the summer. I use normal mode and avoid bottoming the charging needle when braking.
I'm getting around 36 MPG for my commute to work. The commute is about 5 miles on the local streets and hitting about 8-10 traffic lights/stops. The terrain is somewhat hilly around here and I accelerate somewhat heavy (~3,500 RPM in Sports Mode). Personally, the low MPG I attribute to the terrain, stop and go commute, and somewhat hard acceleration.
If I visit my in-laws about 60 miles round-trip, my MPG will climb back to around 39-40 MPG.
You may ask why I got the CT for such a short commute, well it was either a Mazda 3 or the CT, and seeing the CT at the dealership sold me right away.
Got my car in October 2012. I'm in LA County and I'm currently getting 43mpg with my current tank. Initially below 40 mpg when first got ther car. I agree with bumping up the psi of your tires. I learned this from other posts in this forum for better gas mileage. Good luck!
Discussion Starter #8
Thanks for all the replies! I will check the tire pressure and see if that helps. If not, I will definitely take it in to the dealer.
It might be the short commute. It hasn't gotten really cold up here in San Jose. So I don't think it is the temp.
On my way to work, I actually get on the highway, where I average 60MPH. On the way back, I take streets where there are several stop lights.
I also live in the Bay area, East Bay to be exact and have an overall average of about 46 mpg. I use Costco and Chevron, I usually just keep it on normal mode.
The California gas may be a small factor, but I believe the bigger factors are:
-short commute: I have a 60 mile one way commute in So Cal, and I find the car really doesn't warm up (engine oil, not coolant) for about 20 miles. Once warm, the car gets much better MPG. I have 22K miles on mine now, the worst tank was 50 MPG, the best 60 MPG. If I did lots of short trips with a cold car I bet it would be about 40.
-speed: you already found out how higher speed sukssss gas...traffic on my commute dictates I go about 55 mph and I notice if it is about 50 mph the fuel economy is noticeable better. Of course, it is not practical to drive 50 mph when traffic is going 75 mph or if you need to get someplace in short time, but when traffic dictates it, you benefit in fuel economy.
-"eyes up": they teach you in high performance driving schools to look ahead to see whats coming up. This can translate to non-racing driving to plan ahead to avoid unnecessary braking and accelerating.
-tire pressure: the tire manufacturer, Michelin, states maximum pressure is 51 psi for my tires, I inflate them to 50 psi and notice several MPG increase. This is still within the manufacturers recommendation, so hold the hate mail. This is higher than Lexus' recommendations, but they have an ineterest in providing a smooth ride (note the number of posts of people complaining of the rough ride....). Yes, it rides a little rougher. No, there is no significant signs of aberrant wear on the tire as the tire is still within manufacturers recommendation. I have inflated my tires to close to the max on all of my cars for the last 20+ years without any problems. In fact, tire shop personnel are amazed at how many miles I get out of a set of tires.
-weather: best mileage is when it is hot outside, even 50 F is "cold" here where I live and I see a 1-2 MPG decrease. Rain also reduces your mileage by increasing rolling resistance.
-engine oil: this is very anecdotal, but once I used Mobil1 0w-20 and it seemed like it was harder to get the better gas mileage. I use Toyota 0w-20 exlulsively now. Research on Bobistheoilguy.com shows the Toyota oil to measure at a thinner viscosity than the Mobil1, and it has more antiwear ingredients (more slippery??). Again, my experience is anecdotal and impossible the document.
Driving many very short trips I'll get less than 40 indicated for sure. If I get on the freeway, after having reset from a new tank of petrol, and keep it about 67mpg it will pop up to 46 indicated. I think your low MPG has to do with your short daily commute mostly. I pump my tire pressure up higher too.
51 psi???? thats really really high isnt it??
the recommended is 32psi? i do pump it higher, but the maximum i'd pump is 36psi.
I never get the kind of mileage they claim on the EPA sticker. Last tank was 32 MPG (actual vs. the readout which is 2 MPG optimistic). That last tankful was a little lower than normal. I've been getting 36 MPG since buying the car last year, but bought gas at a different station and the MPG was immediately lower.
I am averaging around 46MPG based on Fuelly. (48.5 based on the car's readout). I've been able to hit 48+MPG twice. My worse MPG is around 38 and that was due to a road trip from the Bay Area to So Cal. I was cruising between 75 - 80 MPH. Anything above 70 MPH kills your MPGs.
In the winter, gas stations use lower quality gas. I, too, have seen an ~8mpg drop from my average. Went from 50 to 42.
What do you base your max on? The tire manufacturer says the max is 51psi. (At least the ones on my car.) If you don't like the stiff ride, fine, but I am pretty sure that there is no real basis for limiting it to 36 except personal preference. Personally, my F-Sport has such a harsh ride that I can't tell the difference on the highway. I pump them up to about 48 when I am going on a trip and back off to about 40-41 around town, when I get much better mileage anyway. That highway speed really kills the mpg.
Discussion Starter #18
I thought this might be the case, so as a test, I filled up, got on the freeway, reset the MPG gauge, and set the cruise to 68 MPH. After about 10 minutes of cruising along at that speed, on mostly flat freeway, my MPG was at 38 MPG. I double checked the PSI in my tires, and it is the same as I had it in PA.
I am going to open a new thread about the battery fan which comes on every other week. I honestly think there is a problem with the hybrid battery. When I was on the highway, cruise set to 68 MPH, the car would jump into the power range even at the slightest incline. This NEVER happened in PA. I don't believe the battery is putting out enough power.
I am going to open a new thread about the battery fan which comes on every other week. I honestly think there is a problem with the hybrid battery. When I was on the highway, cruise set to 68 MPH, the car would jump into the power range even at the slightest incline. This NEVER happened in PA. I don't believe the battery is putting out enough power.[/QUOTE]
You may be on to something...in 22K miles I have never heard my fan come on....
If the gas you are using has an Ethanol blend, which is usually up to 10% at most US gas pumps, you will see a 3-4% reduction in gas mileage. I'm sure the Lexus EPA estimates were gathered using no ethanol. Google "pure-gas.org", you will find a list of gas stations that offer Ethanol free, or "pure" gas.
1 - 20 of 34 Posts
