1 - 17 of 17 Posts
2012 Lexus CT200H - 111K
my rims from Getyourwheels.com arrived few days ago and I got them mounted.
Wheel: 19inch Avant Garde M510 8.5" Wide
Tires: Firestone Firehawk Indy 500 in 235 / 35 / 19
Rim Color: Race Gold
Vehicle Color: Matador Red
I thought about getting a gold rim for over 6 months and finally did it.
More pics coming soon.
The car in the picture still has the 1.5inch lift kit but I removed that two days ago but haven't taken new pictures yet.
Oh and the Indy 500's are amazing tires. The comfort of the vehicle has greatly increased but mpg has lowered slightly. Overall a major upgrade because of increased traction on the road on straights and especially on corners.
Car Wheel Vehicle Tire Hood
What’s the offset?
So the rim offset is +45... The back can take a max of probably 10mm spacer in my opinion and the front no spacers but possibly a 5mm spacer without lowering and lowering i'm not sure. There are some others who can comment on flush fitment but at +45 offset there are no issues at all running 235/35 r19 on 8.5 rim. My next tires will probably be 245/35/19 or 255/35/19...
..I might get lowering springs. The car is at stock ride height now, and with the 235/35 tires it really needs the lowering to make it look better. Wish I had gone 255/35 but it was out of stock and I was impatient to get the rims mounted. Still doing some research but I will let ya'll know if and when I do!
Nice! How much for the set of Fsport springs.. Are you riding stock or did you graduate to coilovers? I heard the Fsport Springs are out of production so I might consider that.
Two more pics from the day I removed the 30mm Rear wheel spacers and the front and rear suspension lift spacers.
Firehawk Indy 500 Tires in 235/35/19. Grip is the best I have ever driven in my life in dry weather, truly night and day difference from the best of any tire I have ever owned. Wet weather grip is phenomenal. These are not even all season tires and the rain grip is better than any all season tire I've owned in the past, truly insane tires.
Tire Wheel Automotive tire Vehicle Tread
Stock ride height. No spacer in front or rear. Wheel well in front looks naked because there is no fender liner inside. I have a brand new one sitting here that I'm waiting to mount.
Car Wheel Tire Vehicle Land vehicle
  • Like
Reactions: Jspenc360
Discussion Starter · #7 · (Edited)
Just upgraded my 2012 stock rear bumper to the 2014+ rear bumper.
That booty is looking pretty!
I ordered the bumper from Revemoto.com for around $850 and it arrived painted with free shipping included. So really great deal. Once it arrived I removed the stock bumper and fitted this one on. I got the instructions from the Car manual. Two bolts near the trunk lid and two bolts one on each side of the rear well need to be removed and then the rest are plastic clips.
You can see in the picture that there is a plastic piece missing from the center of the rear bumper. That part is still on the way from the lexus shop. You can also see the hitch that I installed as well.
Tire Automotive tail & brake light Car Wheel Vehicle registration plate
This is the car at the alignment shop for the recent rim upgrade.
Discussion Starter · #8 ·
Took some pics this week to show the quality of the new painted rear bumper from RevMoto.
Wheel Tire Car Building Land vehicle
Tire Wheel Land vehicle Car Automotive tail & brake light
  • Like
Reactions: TobiasSing
Discussion Starter · #9 ·
Some night pics from yesterday…
Wheel Tire Automotive side marker light Car Vehicle
Tire Wheel Car Automotive parking light Vehicle
  • Like
Discussion Starter · #10 · (Edited)
Here are the things I’ve done to the car since my last major update...
1. Installed OEM Lexus Rear Bumper Protector.
2. Installed new OEM Fender Liners on front left and right.
3. Oil change with PENNZOIL Ultra Platinum 5W-30 (Make sure you get the “Ultra Platinum”. Not just the “Platinum”)
4. Installed Mud Flaps on the two front wheels. I have the rears and will install those but I ran out of time at the DIY garage I use to do work.
5. Installed Morimoto Lexus/Toyota LED Fogs. (Previously I was using the OEM fog housing but with HID bulb and 35W Ballast) . Fogs are instant ON now, I still have 35w G5R HID projectors for the headlights. I will not be getting rid of those.
114K on the Dash.
  • Like
Discussion Starter · #11 ·
Today I installed the rear mud-flaps.
installation was pretty quick about 10 minutes per side.
1. remove wheel.
2. line up mud flap and score holes where the metal retainer will hold.
3. attach metal retainer to plastic and using a cordless hex driver, drive the screw threw the fender plastic.
4. back out the screw and then put on the mud-flap and then drive the screw threw it and into the metal retainer.
Tire Wheel Car Vehicle Motor vehicle
Tire Wheel Vehicle Car Automotive tail & brake light
Tire Wheel Automotive tire Car Tread
Tire Wheel Vehicle Automotive tire Synthetic rubber
Tire Wheel Vehicle Automotive tire Car
  • Like
Discussion Starter · #12 · (Edited)
Wheel Tire Vehicle Sky Motor vehicle
Ladies and Gentlemen, today the Lexus CT is hooked up and ready for the 1300 mile journey to our new home.
To prepare for our trip I purchased and installed the CT200H Hitch and the wiring harness from etrailer.com. I also purchased the hitch lock from Uhaul. I did a fresh oil change with new filter yesterday with Pennzoil Ultra Platinum 5W-30. And the transmission oil was last changed 3 months ago in August. I will be doing another transmission oil change as soon as I arrive to the new city and home.
As long as you change the transmission oil regularly there will be no harm to the vehicle. Heat is what breaks down and oxidizes transmission oil this leading to issues. There is no such thing as a lifetime transmission oil.
115,404 miles on the dash.
  • Like
2015 eminent white pearl
1. remove wheel.
I have these too. They really help keep the car clean.
Discussion Starter · #16 ·
I can't believe its been almost a year since I last posted an update!! Time Flys!!
Well, I've been busy with my new job in the Sunshine State of Arizona, and also some business ventures so I haven't been in the forum since my last post but I will be having more updates very soon!
The car has had some wear and tear and I will post pictures of everything that has happened to the vehicle. I have a few maintenance items that NEED to get done for my piece of mind.
Discussion Starter · #17 ·
Things I need to do:
1. I replaced the windshield when I got to Arizona due to a huge rock chip I got in December 2020 when I was out of the country. The breakage grew and grew to the point it was no longer repairable. The new windshield has not tint on it and I'm really suffering the heat. The old windshield was tinted with 3M Ceramic 70%. I will need to tint this replacement windshield because Arizona has some serious heat!!
2. I also had the front and rear passenger windows replaced last year due to some petty thief's looking for things in my car. This happened when I was living in Downtown Portland, Oregon last year. So I've basically not has any tint on those windows as well since they've been replaced. Alot of heat is pouring in through those windows every time I drive out and I can't take it anymore so I have to get those windows tinted soon as well.
3. Since I've now lived in Arizona for almost a year now, I've been managing my AC system which is not working 100%. The AC cools down once the car has been sitting for a while, but once I'm in the 105 degree Arizona sun, then AC will only cool the car when it's driving. I replaced the AC evaporator in the dashboard in 2019 and replaced the expansion valve but that didn't fix it. The next thing I'm going to do is replace the AC compressor and replace the AC condenser, I'll also need to put in a new expansion valve since thats required anytime the condenser or AC is replaced.
4. I drove to Nogales, Mexico 4 days ago, and when I was coming back, (while inside Nogales, USA), some guy trafficked into my lane without putting his turn signal on. I averted a major disaster by quick reaction but his car still hit my front left (driver side). He said it was totally his fault and he was driving some piece of crap car. I didn't even bother and just drove off towards home after a 10 minutes. Driver side mirror is smashed, and Driver side fender is smashed. Driver rim is also scrapped.
5. Check engine light came on about 2 weeks ago and the code is for Mass Airflow Sensor (need to fix)
6. TPMS sensors in the new rims are not working (at least one of them is not working), I didn't request the OEM TPMS sensor when they built the rim at GetYourWheels.com, I should have bought OEM sensors!! 😒😩😫
Wheel Tire Vehicle Car Automotive lighting
Fender/Bumper and Rim damage from the accident.
Car Vehicle Tire Land vehicle Wheel
Side view of the damage.
Mirror Automotive side-view mirror Vehicle Hood Automotive lighting
Cracked mirror.
Vehicle Car Automotive lighting Motor vehicle Hood
Passenger side windshield moulding was cracked during removal for windshield repair. It held good for a few months but blew away in the wind on my way to Vacation in Mexico.
127,000 miles on the dash.
1 - 17 of 17 Posts
