1 - 20 of 39 Posts
Has anyone swapped out their base model front grille for the F-Sport? I just bought a non f sport CT (didn't have time to build) with all the features I wanted...minus that beautiful grille. I found the OEM parts at:
Upper grille, 2014-15, W/F SPORT for 2015 Lexus CT200h 5311176040 Confidently order now with confidence.
From the diagram comparisons, it doesn't look much different than the non f sport. Also been combing through the threads with no success. Any help in the matter would be appreciated.
It is a direct swap. The base model bumper cover and F-Sport are the same. You just have to cut out the opening for the splitters/fog lamp covers. (just to slide the tabs in). The bumper cover already has the cut-out diagram on the back. I bought upper and lower F-Sport grilles and r/l fog lamp covers (splitters). I'll post some pics once it's all finished.
You can get a much better deal here:
https://www.parts.com/index.cfm?fus...45&section=BODY HARDWARE&Title=Lexus-CT200h-F Sport-L4-1.8- Liter-ELECTRIC/GAS
Just did mine with OEM F-sport grills. Such a better look. Only took about 2.5 hours.
Hi Emery,
Any tips you can give us to overcome anything? Did you have to do any cutting?
I have the sport grille at home waiting but I haven't gotten started, yet. I may try to get the sport foglight bezels and some Halo fog lights before I attempt anything just because I assume I'll have to take the bumper off and I would rather knock it all out at once.
I'm trying to find someone that may have swapped out the bezels so I can verify that there were no issues. I'm getting conflicting stories when I look at parts online.
Yup, the first gen and second gen bumper covers share the same pin locations. Following his write up will work to remove the bumper.
Removing the grill is pretty easy as well, they're pretty much all plastic clips, a couple screws.
I followed his write up and was able to change my grill as well.
I’m trying to swap my 2011 bumper for the second gen with that f sport grille. All I’m finding online are each individual piece (top grille, bottom grille, top chrome trim, bottom chrome trim, and bumper) separately for 200+ each and I’m wondering if anyone knows anywhere to purchase at least both grilles if not the complete assembly as a package
Yes I swapped out my 2015 base model grill for the F-sport grille. Was pretty simple swap. Just get the upper and lower.
1 - 20 of 39 Posts
