When parking what do you do first park button or parking brake?
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: When parking what do you do first park button or parking brake?
  1. #1
    Jan 2014
    6
    Does it matter if I push the park button and then press the parking brakes.
    The manual says to press the parking brakes and then put it in park.
    Is there any difference?
    Thanks!
  3. #2
    Junior Member Rich2508's Avatar
    Aug 2013
    Derbyshire, England
    4
    I never bother pressing the Park button, if you switch off the power it activates Park for you. I usually activate the parking brake first if I am on a slope and then switch off, but if I am on the flat I just leave it alone and switch off.
    2013 CT200h Luxury Nav. Mesa Red, Ivory Leather. 2008 Ford S-Max, 2005 Ford Streetka, 1983 VW Golf GTi.
  4. #3
    Aug 2011
    Coral Gables, FL
    842
    I have never pushed the parking brake because there are no hills in South Florida. The only time I press the "park" button is when I don't want to turn the car off, such as when I am waiting for my wife to come out of the grocery store and want to keep listening to the audio.
    I just turn off the car and walk out. No parking brake, no "park" button as a general rule.
  6. #4
    Jun 2011
    Culver City, CA
    180
    Well, I've tried it both ways and finally decided on "push park first, then set the parking brake". I decided on this because when I do it "per the manual", the car moves slightly when I press park (after the brake is set). Also, and I know I'll draw fire for this, but "park" uses the transmission as the brake, exposing it to unnecessary stress, which could lead to additional wear and tear. The parking brake is specifically designed for this purpose and should be the primary system. “Park” acts as a backup to the parking brake! I live in earthquake country, so keeping the car from moving, even on level ground, is a priority here.
    2011 Lexus CT200h Premium w/Navigation & Premium Audio, Daybreak Yellow Mica / Black Nuluxe
  7. #5
    Jul 2013
    80
    Quote Originally Posted by Rich2508 View Post
    +1
    I rarely use the park button.
    Sent from AutoGuide.com Free App
  8. #6
    Moderator midcow3's Avatar
    Jul 2011
    Houston, TX
    875
    2011Matador Red Mica CT Premium Black Nuluxe Interior with Custom Installed Sound, Navigation, Morimoto 55W 6000K HIDs, Xenon White 96-SMD LED fogs.
    2013
    Race Red Focus ST, Smooth shifting 6-speed manual. Recaro black leather seats. 2 liter engine. Awesome power 252 Hp, 270 ft-lbs torque = 2,000-4,500 RPM. No turbo lag. Decent mileage, achieving 28 mpg overall rated 23/32. Interior space 23.8 cu ft cargo with all seats up. Audio, light years better than Premium CT. FUN FACTOR 10 out of 10.
  9. #7
    Dec 2013
    NNJ
    7
    To save the transmission from having to deal with the weight of the car, I always engage the parking brake in neutral. Then I let the parking brake hold the weight of my car. Finally, I'll put the car in park. It's a habit I've picked up from owning my last car.
    2013 CT200h F-Sport - Obsidian
    Volk CE28RT - Kics R40 - Michelin Super Sport - Injen Short Ram Intake - F-Sport Springs - F-Sport Sway Bars - Tom's Chassis Bracing Set
    AIMGAIN - Body Match Grille Surround - BeatSonic FD03 - ARC Oil Cap - RX350 HID Retrofit - Nokya Hyper Yellow Foglights - LED Bulb Swap
    Admit nothing. Deny everything. Counter with false accusations.
    11B Infantryman / 25U Signal Support Systems Specialist
    Fidelis et Fortis
  10. #8
    Jun 2012
    990
    Quote Originally Posted by nabbun View Post
    Yes if you're on a hill as that's what the parking brake is for. There is no weight when you are parked on level ground.
  11. #9
    KKM
    KKM is offline
    Mar 2011
    352
    I think it's a good habit to set the parking brakes especially if you are parked on the street. If the car parking in front or back accidently bumps you while parking, 4000 lbs no matter how low speed, is still a lot of force on the gears if you don't set the brakes.
  12. #10
    Oct 2014
    5
    Kkm is absolutely right. And for me, I'll hold with right foot brake, step on parking brake with left then press park or power.
  1. Advanced Parking Guidance System
    By CTinATL in forum Lexus CT200h General Discussion Forum
    Last Post: 01-05-2014, 02:25 PM
  2. Rear parking sensors
    By GKAPPE in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 03-07-2013, 09:04 AM
  3. Question about parking sensors
    By Holycow in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 05-17-2012, 12:40 PM
  4. Parking sensors?
    By hc806 in forum Lexus CT200h General Discussion Forum
    Last Post: 09-13-2011, 10:50 AM
  5. CT200h in parking lot
    By akimoto in forum Lexus CT200h Pictures
    Last Post: 07-11-2011, 12:47 PM
