General HID info - Page 4
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 45
Thread: General HID info
  1. #31
    Senior Member motionisgay's Avatar
    May 2013
    163
    Quote Originally Posted by Vester72 View Post
    I'm still curious too as I had and still have the same issue.
    Does anyone know if it's a fuse issue? I know for sure it's not a bulb issue on mine.
    Did you end up getting a harness? I am almost at that point. I'm going to go out and check my fuse box to see what if I can find any dead fuses.
    I would assume this is the harness that we'd need. Low Beam: H8/H9/H11 - Relay Harnesses from The Retrofit Source Inc
  3. #32
    Senior Member Bill's Avatar
    Apr 2013
    Florida
    383
    based on wiring the low beam signal comes from an Integration Relay that has a 40 amp fuse. both the drivers and passengers low beams come from this relay so if the fuse if blown you would have no low beams at all on either side.
    so if you have verified that every part of the HID kit on the passenger side is indeed working then you will need to test the low beam wire in the OEM harness to see if there is voltage there.
    I would suspect that you may have damaged the relay output of the Integration Relay of the vehicle if there is no voltage present in the harness.
    Many HID kits say they do not require a relay and they are 100% plug-n-play. I have never put in a HID kit without a relay regardless of what they say. Why take the chance of damaging something when a few extra minutes and a couple of bucks could prevent it.
    2012 Starfire Pearl CT200h
    Base...but modding all the time
    12 volt is my life...
    MECP Master Certified
    ASE A6 Certified
  4. #33
    Mar 2012
    Boston, Ma. USA
    85
    Blog Entries
    Quote Originally Posted by motionisgay View Post
    I tried that.... No dice. Thanks for the suggestion. I'll try anything.
    Sent from AutoGuide.com Free App
    Have you tried calling the Retrofit Source for advice ? If not, ask for Andrew and mention this forum...he knows that I recommended his shop here. He's very knowledgeable/helpful: Contact The Retrofit Source Inc
  6. #34
    May 2013
    163
    Quote Originally Posted by viper1 View Post
    I'm almost at that point. I'm gonna do a little more fiddling before I break down and call. I want to play with a voltage meter and try to decipher it on my own. I'm going to try wiping everything down with alcohol and see if that makes a difference. Thanks everyone for the advice. You've all given me a lot to think about.
  7. #35
    May 2013
    163
    Ok, so after another hour of fiddling, I broke down and called TRS. I described my problem and told Zach everything I've done, and he said he was pretty baffled, too. I told him how I had wiped down everything and swapped all parts from one side to another, and tested numerous combinations. I also re-installed the original bulbs to make sure that power was still coming from the car, which it is.
    Zach said that they have had other customers calling with similar stories recently, and that they think it has something to do with the colder temperatures and the new ballasts that are made by Morimoto. He said that they have been storing some of the ballasts in their freezer and then testing them to see if they can get to the root of the problem. He assured me that they are working to get a solution and that when they figure out what will fix my problem they will contact me and send me what every it is that I'll need.
    I hope they can figure it out. I felt bad, because I don't want to send it all back, but right now it's pretty useless to me and is sitting back in it's box in my basement.
  8. #36
    Apr 2013
    Florida
    383
    Something isn't adding up here...
    You tested the "bad" ballast and HID light on the drivers side and they worked. Now you have put the OEM bulb back in and that works. I take it you put the drvers side OEM bulb back in also? Does the passenger side bulb look dimmer then the drivers side? Now they are saying that cold weather may be to blame? So why does it work on the drivers side then? Have you tried putting the "good" drivers side ballast and HID light on the passenger side to see what happens?
    So here is my $.02:
    It is possible that the Integration Relay output for the passenger side may have an issue where it is not supplying enough current to keep the HID ballast happy (or the ballast is asking for too much current at start up). That would make sense seeing how the ballast works on the drivers side but not the passenger. A simple test would be to add a relay to the passenger side harness (cutting and splicing will be needed) and see if that solves it. The Integration Relay then would only have to trip a relay instead of a ballast. Many ballasts require a good amount of current during start up but then lower the amount when the lights are warmed up. (I don't care how many manufactures claim relays are not needed; it's a simple device that can save a lot of headaches later).
    ASE A6 Certified
  9. #37
    May 2013
    163
    Quote Originally Posted by Bill View Post
    So here is my $.02:
    They sent me a replacement ballast, the bad one was discarded... There is still an issue. TRS says that they don't recommend the relay for our vehicle. Like I said, they have had a few other calls with the same issue, and I am going to just have to trust that for now.
  10. #38
    Jul 2013
    80
    Did they say why they recommend against using the relay?
    Everyone I talked to recommends the relay and it fixed my issue. I used the Xenon Supply kit with mini digital ballasts - but I think it is virtually the same as the TRS kit.
  11. #39
    May 2013
    163
    Right now I'm kind of wondering the same thing.
    How do you connect it to the car? I might just order one and try it in the meantime.
  12. #40
    Jul 2013
    80
    I found a diagram here, but I used the fuse box under the hood and it was very easy and eased my concerns as I'm in Chicago and was worried about the HIDs working in sub zero temps (I drive to work).
    Here is the thread: https://www.ct200hforum.com/forum/lexus-ct200h-engine-technical-discussion/118776-12v-terminal-fuse-box-2.html
    T
    he red animation (looks like a small mushroom) - lift that cover off and attach the relay to that 12v connection there and the HIDs will fire perfectly.
    You only need to connect the driver side light connection to the relay and the auto lights will work perfectly.
    Relay I used: XS Blog - HID Wiring Harness Explained
  1. Xtreme HID 4300k Philips Xenon HID Kits from KBcarstuff (used to be xenondepot)
    By Kevinaldo in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 12-17-2013, 06:35 PM
  2. General CT200h info...
    By viper1 in forum Lexus CT200h General Discussion Forum
    Last Post: 12-11-2012, 09:38 PM
  3. I'm looking to go from NON HID to HID, Voids Warranty?
    By LxTxNx in forum Lexus CT200h Appearance and Body
    Last Post: 08-19-2011, 11:25 AM
  4. More categories under General Discussion?
    By YuDanJa in forum CT200hforum.com Site Issues & Website Help
    Last Post: 05-20-2011, 07:20 PM
