Key Fob battery...
NEWS
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Key Fob battery...
  1. #1
    Oct 2011
    42
    Key Fob battery...
    My 3 week old CT is showing signs that the fob battery is weakening, as sometimes the car will not detect its presence unless I hold the fob to the Power button. How long do these batteries last? Have others experienced the same occurence, but the battieries were fine and it is just a quirk with the system?
    Lexus CT200H Forum
  3. #2
    Senior Member Chunky1234's Avatar
    Mar 2011
    UK
    182
    Does it happen all the time or in one particular place? Reason I ask is this might be interference and not battery.
  4. #3
    Feb 2012
    SF Bay Area
    21
    When I was at the dealership test driving the CT, the sales guy was having exactly the same problem. It turns out that my Prius key fob was interfering with the Lexus one. When I moved the Prius fob far away, all was fine with the Lexus.
    2012 CT200h: Tungsten with Black Leather, LEDs, NAV, Premium Audio, and Illuminated Door Sills
    2010 RX450h: Truffle Mica with Tan Leather and everything else
  5. #4
    Oct 2011
    42
    It happens both when I'm inside the car, and when I'm outside and try to lock-unlock the door by touching the handle. I don't have the second fob readily available, but I will get that one and see if problem is resolved, and if it is, I place fault on the individual fob/battery.
    I had a remote control for a GM vehicle in pocket, I will stash that too.
    Thanks for the comments.
  6. #5
    Moderator audi4t's Avatar
    Feb 2011
    Madison Ct.
    669
    IPhone interferes with fob and my wife has a pocket book that shields the fob signal.
    Premium Fire Agate Pearl / Caramel / Bamboo Dash Trim / Shark Fin Antenna / Illuminated Sills / F - Stainless Sport Pedals / Painted Calipers / HID Slim Ballast Kit - 55 watt 4500 k / White Fogs / LED Interior Lighting
    http://audi4t.blogspot.com
  7. #6
    Senior Member Dirvin's Avatar
    Jun 2011
    Houston, TX
    242
    Battery life
    Ive never had to replace the battery in a Lexus key yet. I keep my cars 3-4 years so the battery lasts at least that long in an electronic key. I would assume the key fob battery is similar.
    2012 Tungsten Pearl, Water Gray Leather, LED lights, Illuminated Door Sills, NAV
  8. #7
    Dec 2011
    15
    I have the same issue...how do you know the iphone interferes with it?
  9. #8
    Jan 2012
    So Cal
    259
    My wife has her iPhone in the same purse as the key fob and it works just fine. I have my iPhone in the left front pocket and key fob in the right front pocket and it works fine.
    I would try the other key fob and see if it is the key fob or the car.
  10. #9
    Feb 2011
    Madison Ct.
    669
    If I have the iPhone and fob in the same pocket the car doesn't recognize the signal and the door will not lock/unlock. This must be a proximity effect. I guess this is why devices have the FCC warning signs on them. Devices can cause mutual interference.
    My wife's pocket book that causes issues has a "metallic" finish - which I assume shields the fob signal. She can be standing next to the car and the door will not unlock until she takes the fob out of the pocket book.
  11. #10
    Member jessright's Avatar
    Dec 2011
    Northern Virginia US
    46
    The manual does say to keep the FOB away from other radio wave emitting devices as much as possible, or I guess as is practical to prevent premature discharge of the FOBs battery.
    2012 CT200h Tungsten with Black Nu-Luxe, Premium Package and NAV. 2003 Honda S2000 Blue on Blue, 2003 Nissan Murano, Brown /Terra Cotta
  12. Remove Advertisements
    Lexus CT200H Forum
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Battery upgrade
    By Cyberformula in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 01-03-2012, 06:28 PM
  2. Hybrid battery charging process
    By LowCarb in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 10-30-2011, 08:11 PM
  3. Lithium-ion battery
    By obiwan in forum Lexus CT200h General Discussion Forum
    Last Post: 09-25-2011, 10:52 AM
  4. Battery Level For Car
    By bondguy in forum Lexus CT200h General Discussion Forum
    Last Post: 09-09-2011, 03:10 PM
  5. Battery Life while 'Parked' running AC
    By Boldlygo in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 07-22-2011, 12:30 AM
