Cold start knocking, vibration, rough idle.... - Page 4
NEWS
Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: Cold start knocking, vibration, rough idle....
  1. #31
    Senior Member stormchaser's Avatar
    Mar 2016
    161
    Just to let you know. I've cleaned out my EGR valve and pipe from it and have twice used injector cleaner in the fuel. My car hasn't done it since this and we're having cold weather here in the U.K. But not as cold as you are having. It's a simple DIY process to clean these parts which I believe will cure it. In the U.K. We don't have these recalls for it. I hope this helps you.
    Sent from my iPhone using Tapatalk
  3. #32
    Feb 2017
    4
    [QUOTE=stormchaser;1790978]Just to let you know. I've cleaned out my EGR valve and pipe from it and have twice used injector cleaner in the fuel. My car hasn't done it since this and we're having cold weather here in the U.K. But not as cold as you are having. It's a simple DIY process to clean these parts which I believe will cure it. In the U.K. We don't have these recalls for it. I hope this helps you.
    Thanks for your answer!
    One Lexus dealer I've contacted also indicated they did this repair to multiple CTs and cleaning the injectors was the fix for 125$ CAD.
    It's winter here in Canada and I'm not cutrently equiped to do the repair, I will ask the closest Toyota dealer to clean both EGR and injectors since it wouldn't be covered under warranty (I guess?).
    I will keep you posted.
  4. #33
    Mar 2016
    161
    You're welcome.
    It'll be interesting to know your outcome on this. Good luck.
  6. #34
    Feb 2017
    4
    I contacted the closest Toyota dealer to have my EGR valve and injectors cleaned; they told me they'd never perform that kind of work on a Prius. So I contacted another closer Lexus dealer, since they gave me a hint about injectors cleaning. They confirmed there's a new TSB L-TCI-3635 from Dec.5t 2016 to clean a valve to cool exhaust gas (I guess it's the EGR valve), reprogram ECU (I think)... 2,5h time and multiple gaskets, waiting for their estimate. They told me it's no covered by the powertrain warranty! I'm really upset right now, all the components they told sounded like engine component, I don't understand why it would not be covered by powertrain warranty!
  7. #35
    Jan 2017
    9
    Quote Originally Posted by stormchaser View Post
    do you have the links to the youtube vids that you used to do this DIY process? can you share? that would greatly help out.
  8. #36
    Mar 2016
    161
    I don't have any links to videos. I knew what needed to be removed and cleaned. It's very simple to do. I do know that there are videos on YouTube but are for the Prius which is the same.
  9. #37
    Mar 2016
    161
    Found this on YouTube.
  10. #38
    Junior Member Jsxx's Avatar
    Mar 2016
    Hi. Which injector cleaner did you use?
    Sent from my SM-G920F using Tapatalk
  11. #39
    Mar 2016
    161
    I used Redex.
    Use half bottle to a tank full of fuel. It's certainly made a difference to my engine. Much smoother now.
    For cleaning the EGR and Pipe I used this.
  12. #40
    Apr 2017
    Columbus, OH
    So i remember getting the cold weather engine knock on start up a few times in the winter. The last few months i've gotten the P0403 Exhaust Gas Recirculation Circuit Malfunction code. First time i just reset, within a week it came back on. Car ran normal, so started researching. Came across the EGR pipe cleaning vid on youtube on prius. So i tried that, it was gunked up a bit. Then reset CEL and went a good month and half and it came back. So came across this forum and thought i would sign up. Seems like alot of good informatino here. So here i am. I noticed there was a TSB for replacing the intake manifold with upgraded one, any way to tell what the difference is between the old and new? And if there's a part number for old vs new. I only found the following part number17141-37150.
    Or would taking the manifold out to clean is enough?
    Thanks in advance,
    -D
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Car sputtering on cold start?
    By Portishead in forum Lexus CT200h General Discussion Forum
    Last Post: 02-10-2014, 10:09 PM
  2. How does your car drive, Shaky? rough? Smooth?
    By evicfinite in forum Lexus CT200h General Discussion Forum
    Last Post: 08-24-2012, 01:09 PM
  3. Hybrid Engine Cold Start (Temperature Gauge Missing)
    By pauly_shaw in forum Lexus CT200h General Discussion Forum
    Last Post: 01-21-2012, 03:54 PM
  4. Vibration
    By Huskies in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 05-10-2011, 09:58 PM
