Remote engine starter kit (pics) - Page 4
NEWS
  1. Welcome to Lexus CT200H Forums General discussion forum for Lexus CT200h
Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: Remote engine starter kit (pics)
  1. #31
    SID
    SID is offline
    May 2011
    Moscow, Russia
    89
    I would like to write few words about RES installation process.
    The installation procedure is well-described in the equipped manual (read this thread for pdf - link), so i don't post images about that.
    The whole process took around 2-3 hours for the first time If your car not from US-market, then i'm sure i will have the same problem
    First of all, here is EWD
    Look at the F5 connection point - it's 12v running from the ignition relay. And this is a trouble for non-US versions, the car harness mother-socket
    doesn't have the necessary pin for the RES harness.
    Circle - father-socket of the RES harness connected to the car's mother-socket.
    Yellow and Blue wires - F7 and F3 connection points
    Black wire - missing F5 connection point.
    Well, i have to route my own wire, i choose the "seat heater" buttons from the center tunnel (read the owners manual about ECU Ig2 fuse and choose yours... )
    The total CAR destruction will look like...
    Here is the archive with all necessary tech-doc: http://narod.ru/disk/30969890001/RES INFO.RAR.html
    2011 Lexus CT200h Daybreak Yellow Mica/Light gray leather
    Lexus CT200H Forum
  3. #32
    Sep 2011
    14
    Does this require a FOB with the trunk release? That's what a dealer said I needed when i wanted to buy the kit online. Going through the installation manual, it looks like the standard key FOB.
    Thanks in advance!
  4. #33
    SID
    SID is offline
    May 2011
    Moscow, Russia
    89
    Quote Originally Posted by bumski667 View Post
    Does this require a FOB with the trunk release?Going through the installation manual, it looks like the standard key FOB.
    My FOB without this button, so this is not necessary
    I believe that "keyless entry system" option is not necessary too.
  5. #34
    SCO
    SCO is offline
    Jan 2012
    Belgian CT200's are missing the F3, F5 and F7 connection point
    Can anyone tell me the connection numbers on the BODY ECU
    I geuss I'll have to route 3 wires but you only have the solution for F5
  6. #35
    SID
    SID is offline
    May 2011
    Moscow, Russia
    89
    Quote Originally Posted by SCO View Post
    That's sucks, man
    I have this scheme:
    As you can see, the 3 and 7 RES pin corresponding with 16 and 4 MAIN ECU pin.
    I don't have dataspec about Main ECU, so you should visit https://techinfo.toyota.com
  7. Remove Advertisements
    Lexus CT200H Forum
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. Remote Touch Arm Pad
    By Chunky1234 in forum Lexus CT200h Appearance and Body
    Last Post: 12-24-2011, 12:50 AM
  2. Internal Pics of engine/drivtrain
    By Bigleftyinaz in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 08-29-2011, 08:13 AM
  3. Remote Start Question
    By ctdave in forum Lexus CT200h General Discussion Forum
    Last Post: 07-29-2011, 01:19 PM
  4. How do you program the key-less remote?
    By william in forum Lexus CT200h General Discussion Forum
    Last Post: 05-03-2011, 02:25 PM
  5. Remote engine start
    By tazzytazzy in forum Lexus CT200h General Discussion Forum
    Last Post: 04-19-2011, 01:55 PM
