Changing your own engine oil - Page 2
NEWS
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Changing your own engine oil
  1. #11
    Member william's Avatar
    Mar 2011
    61
    Quote Originally Posted by Matt_RN View Post
    10k is our oil change interval. Our gas engines aren't running all the time as they would in a normal gas powered car.
    If the Prius engine oil change involves a canister filter refill, then the CT will too, since they have the same drivetrain. My RX had a canister. It's supposed to be more eco friendly. BMW and Mercedes have been doing that for a while. Instead of replacing the whole screw-on filter, only the inner element gets changed out, reducing a lot of waste. Supposedly.
    So for our car, we do not need to change the oil filter? Just replace engine oil and oil inside the canister?
    Lexus CT200H Forum
  3. #12
    Senior Member YuDanJa's Avatar
    Apr 2011
    Fairfax, VA
    265
    Quote Originally Posted by YuDanJa View Post
    oh, by the way...
    Is the oil filter same in a CT200h as the Prius/Corolla/Matrix?
    Toyota Genuine Part: 04152-YZZA6
    So, can anyone confirm this?
    Quote Originally Posted by william
    I guess if someone answers my question, it'll answer yours?
    2011 Lexus CT200h, Fire Agate Pearl / Caramel Nuluxe
  4. #13
    Senior Member cenix's Avatar
    Mar 2011
    222
    Quote Originally Posted by william View Post
    i think you're confusing "canister" for the oil filter element. there is still a filter element that needs to be replaced, but it is housed in a "canister" type of receptacle. as mentioned, mercedes & bmw have been doing this for a long time now.
    in the picture below, the ct200h doesn't use the traditional black colored oil filter, but rather the orange filter element as seen towards the bottom of the picture:
  5. #14
    Dec 2010
    Boston
    83
    Here is the step by step process for the 2010 Prius (Gen 3). I bet that the CT is fairly similar.
    John's Stuff - Toyota Prius Maintenance - Changing Oil
  6. #15
    Apr 2011
    Fairfax, VA
    265
    oh, by the way...
    If anyone cares to know...
    Confirmed...the same part no. works for our CT's.
    I called several Lexus service depts. They were not willing to give up the info...some actually lied to me saying the car is so new they don't have the part info yet (but, if I come in to have it serviced, they'll magically have the part). Others tried to scare me on consequences of putting in the wrong part and why it is important to have it serviced by Lexus. I gave up on them.
    So how did I get confirmation? Had a local authorized Toyota parts distributor call them for me. Instant "yes, it's the same part" from Lexus.
  7. #16
    Junior Member Binmonkey's Avatar
    Jan 2012
    Barrie, ON
    3
    Yes, this is the oil filter I've bought from my Lexus dealer, and it's the same procedure as Gen III Prius. The plastic underbody shield is a tight fit to take down if you're using ramps to raise the vehicle at home. It wouldn't be an issue on a hoist.
    You need a good quality oil filter housing socket, such as this one: http://www.amazon.com/Assenmacher-Sp.../dp/B0015PK3AG
    I've been able to get it from PartSource in Canada.
    Also: The Toyota 0W-20 oil available from the dealer is the best price out there!
  8. Remove Advertisements
    Lexus CT200H Forum
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
  1. is the engine noise an issue
    By Andrewa in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 02-11-2012, 09:03 AM
  2. Engine Rattle
    By Aubergine in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 01-19-2012, 03:11 PM
  3. Engine and fuel treatment
    By Cyberformula in forum Lexus CT200h Engine and Technical Discussion.
    Last Post: 11-26-2011, 09:54 AM
  4. Remote engine start
    By tazzytazzy in forum Lexus CT200h General Discussion Forum
    Last Post: 04-19-2011, 01:55 PM
  5. First CT200h ENGINE photo !!
    By seal in forum Lexus CT200h Pictures
    Last Post: 01-15-2011, 04:23 PM
